Hello all, our gunite pool with "medium gray" plaster was finished in late May/Early June, and while its usually less noticeable when the pool filter is running, there is a lot of discoloration to the plaster (see pics) The start up procedures were all run by the pool builder, who also has the maintenance contract for the pool, so I'm naively assuming they did/are doing all the necessary startup/maintenance whether brushing, balancing chemicals etc. I personally think the discoloration has gotten worse (my spouse disagrees) over the last two months, and I initially assumed that since its done by hand, that there would be some variation, but is this too much? In teh pic of the full pool the tree in the back is casting a shadow over most of the pool, but you can still see the general variation in color. Is something wrong? is this something that can be remedied by say more brushing or chemical rebalancing? Is this likely to get better or worse with time? Many thanks in advance for your help!
