Not sure where to put water level for missouri...my skimmer has a little vacuum port and my water is about a 1inch below it currently..also for winter cover do i keep the cover above it as to not put pressure on the skimmer as cover gets heavy..the wire on the cover can either go above the skimmer or on it but not below it...if i go above the skimmer lid will be exposed is that ok as lines are unhooked..all lines unhooked and stored inside with pump. Also on return jet do i just put rubber plug in it or the little cap. I slammed my pool let it run for a few hours and lowered water and covered have no idea if i did it right my 1st year owning a pool i did wait till water was 60 degrees...any help and guidence is appreciate d
