Minimum VSP Flow or RPM Setting for Pentair Master Temp 400 Heater
Rich807
127
Las Vegas, NV
Ok, I've searched the site & googled but I can't seem to find what the minimum speed for the heater to say running is (either a GPM min or RPM min).
Seen lots of threads / discussions about whether faster flow is better than slower flow but that's not really what I'm wondering today.
Air temps are going to be in the 90s this weekend here so we're heating up the pool. This is the first time we're going to heat up the pool with the heater as it's a newly constructed pool from last summer & we didn't heat the water over the fall or winter months.
ETA: Tried to call Pentair but they're closed for the holiday weekend. Would like to ask what speed (or water GPM rate) is most efficient for my heater.
I read on a different thread that the PentAir master temp 400 is between 40gpm and 120gpm. Regardless if your doing 40gpm or 120gpm the heater will still be putting out 400k btu, therefore it doesn’t matter on the “speed”.
I do 45gpm so you exceed the minimum so the heater does not automatically turn off and save electricity in the process.
Reactions: Rich807
Rich,
Each pool, and how they are plumbed, are all a little different.. There is no magic number..
Just increase your pump speed a little at a time until the pressure switch in the heater just kicks on.. Add about 100 RPM and call it good.
Reactions: TaylorN and Rich807
Well crud. Heater ran fine for 3-4 hours then I noticed it wasn't running. Unit's control panel display no longer working. Heater Button on pool panel dead. Pentair App shows 'heater on' but it's not. Everything else working (pump, app functions controlling the pump, lighting controls etc). Checked the glass fuse inside the unit, it's not blown.
Not sure if PB reported any of the equipment for warranty purposes. Would this be an issue I should go direct to Pentair on?
Please create your signature with details of your pool and equipment. Otherwise we end up constantly asking you what equipment you have when you post questions.
I would open the heater and disconnect the 2 wire fireman’s switch wire and wire nut the heater wires together to put the heater back in local control and see if it comes alive.
Checked all CBs in the pool control box & at main home panel--all GTG far as I can tell. Also, After puled the cover off the unit & cycled the power toggle switch on the heater. Everything else related to the entire pool system is powered up & operating.
Be sure the temperature setting on the heater is maxed out so the ET can control the temperature to what you desire.
Can we assume this heater has worked fine in the past up to now?
Sorry - I see this is your first use -- did you set up the system or did the pool builder?
Be sure your filter is clean -- I do not see how you chlorinate in your signature, nor are there Poolmath records. Our first burst of warm weather could have caused a small algae bloom if chemistry not up to par.
PB set it up. Gas co fired it up first start. It's been on a few times between June last year (when pool was first started after build) & yesterday, but only either by accident or just testing to see if the automation would fire it off (never had indication anything was amiss).
Chlorinate using liquid chlorine. Test using the TF-100 kit. Haven't got around to signing up for the paid version of the app yet so I haven't been logging my chemistry thru the site or via the app. I've been on it pretty much multi times a week for the last month or so. #s have looked good.
Is the heater powered directly from a circuit breaker or does it go through a relay?
Pictures of everything would help.
The power should be going from the circuit breaker to the heater and not through a relay.
How comfortable are you working with electricity?
Equipment should be in my signature block now. If I’ve missed anything let me know & I will add it in.
On the control board, there is a button that says heater. Is the light above that on or off?
Does the heater get power if you press the heater button?
Can you verify if the power goes through a relay by looking in the Easytouch box?
If the Firemans Switch is not being properly closed by your ET then there will be no power to the heater controls.
Easiest way to test is to disconnect the control bale from the two terminals and use a short piece of wire to connect the yellow terminals on the heater and see if it comes alive.
No lights or display at all on control board.
No LED blinking on circuit board.
Pressing any heater button in Easytouch box or on the heater control panel = nodda
LED light on top row of Fenwal box = not flashing.
I assume the power goes thru a relay but I’m not an electrical guy so not sure how to trace it.
Ok. Did what you said & upon flipping the breaker back on the circuit board & control display has power again. Heater will now fire under local control (at the heater). Heater button on easy touch panel still not working
That is because you disconnected the heater from the ET. Now we know the heater is working and that is not the problem. The problem is with the control wire to the ET or the heater relay in the ET.
You have your heater working now. You want to dig into the ET panel?
Do you have a multimeter?
