Minimum canal depth required to avoid vortex, assuming several drains
ANK34HSG
2
South
Hi Everyone,
I’ve hired a contractor to build an infinity pool. It is a good contractor that I’ve had experience with in the past, but our location is in South America, and this is the first infinity pool he has built. As a result, I am doing a ton of research on infinity pools to make sure none of the “rookie mistakes” are implemented by the contractor.
The main issue I’m having a problem with is the depth of the canal that receives the overflow of the infinity edges. The relatively simple calculations regarding this topic which I'm NOT having any problems with are: the overflow amount based on maximum number of swimmers, water in transit, wind “splashing” water over the edge, etc.
The estimate that IS giving me a bit of a headache is the minimum amount of water required in the canal to ensure vortexes do not form directly above the drains that lead to the pump. I’ve found many places on the internet that give me a pretty well-established equation for determining the depth required to avoid vortexes, however what I can’t find is information on what happens to that equation if you have more than one drain in your canal.
Specifics: The contractor tells me our pump pulls 105 gpm, and he is planning on using 2 inch pipes for the canal drains. The equations I’m finding on many pages online (and which are apparently based on the Hydraulic Institute ANSI/HI 9.8-1998 standard) tell me that this configuration of flow and diameter would require a minimum drain depth of 23.31 inches in order to avoid a vortex. However, that equation is only for a situation where you have one drain. The contractor is planning on installing 5 drains in the canal. My intuition tells me that the velocity at which the water will enter each drain will be evenly divided (roughly speaking – I assume some drains will work a bit better than others due to distance to the pump), so that the entry velocity at each drain will be about 1/5 of the entry velocity if there was only a single drain. As such, I suspect the minimum depth to avoid vortexes will be dramatically reduced (which would be great!), as the input velocity of each drain will be much lower – but I have not been able to confirm this intuition by my online research.
For clarity, let me ask the question another way. For example, if I were to have one drain with an entry diameter of 2.31 inches (this is obviously a theoretical value – for ease with the equations), and a flow of 105gpm, then the equations tell me that entry velocity will be 8 ft/s, and the minimum depth required to avoid a vortex will be 19.4 inches. The question is, if I add a second drain of the same diameter (connected to the same pipe/pump in serial), will the resulting velocity into each pipe be half (4 ft/s), and if so, will the minimum depth also be reduced? (I don’t think the depth will be cut in half, but I suspect the more drains, the less speed into each drain, and therefore less depth required to avoid “vortex-ing”.)
Is anyone able to confirm whether my intuition is correct (or incorrect)? And if so, will each additional drain reduce the minimum depth requirement (for vortexes specifically) in a linear manner, or will each additional drain have less and less impact to the minimum depth requirement?
(I’m deliberately not posting details of the size of my pool, because vortex creation is not related in any way to the volume of water of either the canal, nor the pool. As far as I can tell from my reading so far, the only variables related to vortex creation are depth of the canal/tank, water flow, water velocity, and diameter of the drain. Of course there are websites that get A LOT more involved, with Reynolds, Weber, etc. numbers, but I’m okay with the less complex equation that only involves the above variables; I can live with a bit of inaccuracy by erring on the conservative side of any numbers I finally arrive at.)
Thanks a ton!
First, I think the equations you are using are for an unbaffled entry which I suspect is not what you are going to have. A VGBA safety cover on the drain or a trough grate will significantly alter the dynamics of the water entering the pipe and so it is very unlikely it would create a vortex at all unless the water is very shallow.
But yes, it is a linear process (assuming the drains are fairly far apart) so if you have 5 drains and the plumbing is identical in the five drains to the point of combination, then the flow will be divided by 5 and the vortex height is divided by ~5 depending on which equation you are using.
There are several depths that are important to the trough/canal.
The total depth, the depth of water when the edge pump is off and the depth of water when the edge pump is on.
The depth of water when the edge pump is off is less than the total depth and the depth of water when the edge pump is on is less than the depth of water when the edge pump is off.
How much the water in the trough drops when the edge pump is on depends on the surface area of the pool, how much clearance you need to get and the surface area of the trough.
I would suggest that you have at least 18" of water in the trough during operation.
You should make sure that the suctions are all safety compliant.
Even though the trough is not designed for swimmers, it's not unusual for people to get in the trough.
The drains should be tied together and then run to the pump in a single 3" or 4" pipe.
I would suggest the Intellifloxf pump for the edge.
Allen, Mark, and James, thank you very much for taking the time to read my post, and for your very valuable insight. After all the initial research I had done, I felt close to being able to confirm the trough size but not 100% there; your answers really helped!
Initially the contractor said he was going to make the trough have 5% the capacity of the pool. Having read a lot of good posts about infinity pools I knew he couldn't just use a rule of thumb like that; each pool needs to be carefully thought about. It turns out that the total capacity of the trough we are going to end up with, is about 5.4% of the pool (but only filled with the equivalent of 3.6% of the pool when the pump is off and nobody is swimming.) The contractor will probably say "see, I told you so", but I'm very happy I've put in the work and math to end up with a concrete design and number.
Thanks again!
OP - who did the engineering? It’s wise to just outsource the engineering. Collecting data from here & there is a recipe for issues.
I do appreciate the dialogue and the guidance you are receiving above.
Which part of South America?
@ajw22 - I like your post, I just spent a week with Lew & Brian..
