Re: minimax 100 heater adapters for an intex above ground po
First, YOU need to read your installation directions to see what, if any, outlet/inlet adapters were provided with the heater. Either 1 1/2 or 2 inch PVC would work for your setup. You need to also read the threads on this sub forum on the Intex adapters that we make to interface regular PVC piping to the intex equipment using electrical 1 1/2 to 1 1/4 inch adapters.
As a side note, unless your are running the bigger Intex pumps (like the 2650gph one), I doubt if the smaller ones that come with some of the Intex pools have enough pumping capacity to engage a pressure switch which is integral to most pool heaters......don't know what I mean....READ you heater manual. You may have to upgrade to a bigger Intex pump or get a "real" pump and filter setup.
Bob E.
