Microbrite lights modes and colors not working
ArmeniaX
2
CA
I have Easytouch system, and have 3 microbrite lights connected under 1 relay to aux1.
I am able to turn on and off the lights by pushing the aux1 button on Easytouch panel.
However, when I go to Lights section, Turning the lights on and off feature is not working. The modes and as well as colors are not working as well.
I went to Circuit Functions and changed Aux1 to be Inellicolor, Freeze no, but it did not solve the issue.
How can I make the color modes and colors work?
Thanks
Hi Jim
Unfortunately, I do not have a Windows interface to the system.
I ended up calling Pentair; they tried a few things from their side using the remote access - unsuccessful.
Then the guy decided just to reset the system.
After the reset, he setup the Circuit Names and Functions, and everything worked!
So it was just some kind of weird bug or something I assume, the support guy did not provide any additional information.
___
So when the problem was there, turning on and off the lights from the light menu, and changing modes and colors, were not triggering any click sounds on the panel.
After the reset and setup, I could hear multiple clicks when changing modes and colors.
Regards,
Reactions: Jimrahbe
X,
The lights are controlled by the relay.. the number of times the relay "clicks" is what tells the lights what color to be, and if they should be on or off.
Glad you were able to get it working, even if we don't know why?? :mrgreen:
