You can pretty easily test your tap water for iron by taking a very white 5 gallon bucket and filling it with the same fill water you'd use for your pool. After the water settles, take a photo, then add about 1 tbs of 12.5% chlorine to it, stir water... 1 day later, take another photo, 1 day later another photo etc. if there's iron in that water you should notice by day 1 the water turning a yellowish color, and by day 4 or 5 or so, the iron in the water may start falling out to the bottom of the bucket (leaving the bottom stained with iron) and the water color going from yellowish back to normal again.. I've been able to trace a smiley face on the bottom of the bucket with my finger from the iron staining, heh.
(this is totally non-scientific and just some testing that I've done that seems(?) to work and validate iron being in the water?)
If you do it with *2* white 5 gallons buckets, and only add chlorine to *1* bucket, you can see the differences at day 1, 2, 3, 4, 5, etc. If both behave indentically, the one bucket without chlorine, and the bucket with chlorine, then likely you don't have any iron in your water -- because you definitely should notice a substantial difference between the two buckets.
(again, non-scientific here)
