So I am a pool newbie having had this pool for 2 1/2 years with the purchase of the house. I'm the guy who tries to do things himself before calling A professional. I recently noticed that regardless of how often I ran the filter, my pool is not getting clear and algae doesn't seem to go away. Over this time, I have done random backwashes/rinses/shocks as I believe that was what I was supposed to do. Doing research I read that some people replace sand in their filters every 2 1/2 to 5 years. I thought that was the job for me.
After removing the clamp that keeps the multi port in place. I attempted to lift the multi port off the tank. This action resulted in the entire assembly Lifting out. It appears that the tank was only 1/3 full of sand. That would equal approximately 170 pounds of sand when the filter label reads there should be 500 pounds of sand.
I assumed that was the problem with the filtering. I therefore pulled out the old sand and refilled the tank with 500lbs of new sand.
How could I have possibly lost 300 pounds of sand over the course of 2 1/2 years? Am I supposed to add sand every time I back washed the filter?
All that being said, two weeks have passed and my pool is now cleaner than it is ever been.
Lastly, there seems to be a small leak at the bracket that holds the multi port to the tank. It's just a very light trickle. Does that mean I need to replace the O-ring?
