I was reading some other threads on SWG performance and there was a discussion on the maximum flow rate through a SWG should not exceed 80gpm. I think this was for Pentair or CircuPool systems.
I am about to purchase a Jandy AquaPure 1400 because it will link easily to my iAquaLink automation, even though the output of the Jandy is only 1.25lbs per day which is low when compared to similar models of Pentair and CircuPool. I feel this is the best solution for my situation.
I have read the manual online and there is no reference to maximum flowrate. I want to know if I need to build in a bypass when I mount the Jandy SWG. I have a Pentair VSF Pump but it only operates in Speed mode under Jandy iAquaLink system, so I have no way to know my current flowrates at various speeds I am running. My concern is when I run the booster pump I ramp up the VSP to 2750rpm.
My pump is at same level of pool and about 30 linear feet on suction. I do have heater but it does NOT have a plumbed bypass.
Does anyone have any knowledge on this?
