Ignition detection is accomplished by a flame sensing control system known as flame rectification.
The Fenwal Ignition Control Module sends out an A/C voltage to the sensor.
When there is a call for heat and the burners ignite, flame hits this sensor creating a “path to ground through the flame” for the A/C voltage.
When this happens, a pulsating D/C signal, in the form of micro amps goes back to the Ignition Control Module.
The flame sensor is energized with AC voltage, which is rectified to DC in the presence of flame.
The DC current flow is measurable in micro amps (uA).
On gas furnaces, 3.7 uA is a typical measurement and measurements less than 0.5 uA result in interruption of the heating cycle.
On many models, the flame current may be read at the flame current pad built into the furnace control board.
The control board converts the uA measurement to DC voltage (1 uA = 1 volt DC,).
The LED light on the Fenwal box can indicate the following problems:
- Steady on - Internal Control Failure
- One flash - Air Flow fault
- Two flashes indicates flame no call for heat, then the Fenwal is detecting a flame current when it shouldn't be
- Three flashes indicates no flame current being sensed and ignition locked out
www.troublefreepool.com
