2016 heater installation. Main board stopped displaying anything, including on power up from breaker. Automation is Jandy Aqualink.
Heater display board is pre-2021, #42002-0007 rev D. No LED errors on back of board during power up. Confirmed 24 VAC coming to board, both on transformer output and on the yellow and yellow/white input to board.
LED above Fenwal box (35-662944-013) flashes once briefly on power up, indicating Air Flow Fault (correct?) There is no audible "tick" from air sensor and blower motor does not show any life at power up, so checked power to blower motor. Black/output from Fenwal F2 to blower motor measures zero. When the Fenwal is bypassed, power is restored and blower motor comes on with power up (tested only very briefly.)
Assume this means something (relay?) inside the Fenwal is bad. Is there something to debug inside the Fenwal, or just purchase and replace the whole box?
Or, is there some other possibility that needs investigation? No signs of chewed wires or clogged blower so far.
Thank you in advance.
