Quick summary. Mastertemp400 was quick cycling. Pool repair guy concluded new thermistor was needed. It was going to take months for repairman to return, so I replaced thermistor, high limit switch and gas shutoff switch myself. Heater worked for a few days, then heater gave E05 error, so I replaced the stack flue sensor. Heater went back to E01 error. I tried a new thermistor. E05 error.
If I disconnect the stack flu sensor, it will run for about 15 minutes, then cutoff. When the heater runs, the temperature is about 30 degrees off, too cold.
So, is a new control board my only option? Wiring looks ok. I can't see any breaks or damage. Heater is only 3+ years old.
