Hello all, and thank you for the wealth of info on this site. I've searched and searched, and read numerous threads, but want to get others' input before I buy a new Easytouch motherboard.
Symptom - Heater won't power up while trying to use automation (Easytouch panel or screen logic app). When heater turned on using app/easytouch panel, heater display briefly comes on, flashes r14, then powers off after ~2 seconds. Then does nothing.
Troubleshooting steps taken so far:
- Swapped to service mode, turned on pump at pump control panel, turned on heater via ET panel, same problem
- Connected fireman's switch directly (bypassed ET panel), turned on via heater control panel, fires up and works fine
- Crossed green and yellow wires at J19 terminal at ET panel, same thing, using heater control panel fires up and works fine. So I think the wires from ET to heater/fireman's switch are okay. Also leads me to believe the glass fuse right there is fine too.
- Checked voltage of J19 terminal. Reads 25-26v while heater is NOT turned on, but V drops to 0 when swapped to heater ON.
So my first question is, is the V reading 0 at J19 when the heater is ON normal? I'm not electrician, so I don't really know how the relays/terminals work.
Any other questions/thoughts/ideas are greatly appreciated. Thank you
