Moved from here.
Followed steps in this thread. I do have 240 not 120 setup. Have 120V at both L1 and L2. Have 25v at power side of fuse so assume transformer ok? Tried unplugging 24vac, TH, IND, and VAL from the ICM but as soon as I turned power on with all of those unplugged fuse blew.
Have checked for bad wires ad nauseam and they all appear to be in great shape.
So is ICM bad or control board, what next?
Thanks.
I am having a similar issue and have a 2007 Mastertemp 400 that worked great never an issue until last season and I got no lights or power to buttons etc. Quickly found fuse blown and replaced which immediately blew when power resupplied.How are you testing for voltage at L2? One probe to L2 and the other to the jacket (ground)? If so, that is correct. In a 120V connection, L2 is the neutral, and will have no voltage. Single leg voltage (120V) will only be at L1. I don't know what blue wire you are testing.
This is simple. Apply voltage to the heater. Xformer is connected by a plug, 5 wires. disconnect and probe white wire and black wire (supply side), you should get 120V.
If you dont get voltage, stop. There is a problem with the supply voltage. If you do have voltage, reconnect the plug and go to the main board and disconnect the only plug with 4 wires on it. You want to probe the two wires on that plug that were closest to the 5 wire plug that is next to the plug you pulled out, testing the wires on the plug side not the pins on the board side.
No voltage = bad xformer, replace.
Here is the wiring diagram. Hopefully you can make out the wire colors.
[url=https://postimg.cc/image/4zxi708u1/][/URL]
Thanks.
