Mastertemp 400 Burner Problem
netronin
10
SoCal
Pentair Intellichlor IC-40
Moved from HERE
I have gotten a few with this problem and it tuned out to be an igniter. While it still worked, it failed to give flame rectification, and would shut the heater down after a few seconds.
I may have the same issue. AGS light comes on and heat shuts off after 15 or 20 seconds. Shorting out the AGS wires doesn't clear the AGS light. Found a mouse had chewed on one of the ignitor wire covering (but no the wire itself) and continuity was not zero. Hope thats the cause and not the board.
Just to follow up, replacing the ignitor did not fix the issue (AGS light still lit and heater would shut off after 20 seconds). I then replaced the circuit board which resolved the issue.
