Mastertemp 400 AFS error no power to blower
MLCarlson
Active member
Dec 16, 2022
38
Fleming island Florida
Hello, I have mastertemp 400 and recently had to replace blower motor (old one froze up). The new blower would not start and got AFS light. Called Pentair and after troubleshooting no power (jumped F1 and F2 and new blower motor works) checked 24vac terminal and IND terminal and no 24 vac on IND, they said needed new Control board and membrane pad. I ordered newest Pentair board. Installed and have same problem, no power to blower. I have not checked new control board 24 vac on pins 3 of J1 or terminals. I need help verify this new board is working on my older 2016 heater. Please any help appreciated.
It seems odd that the motor froze up.
Did you try to turn the motor by hand?
Can you show pictures of everything?
Was there a lot of corrosion?
What is the manufacturing date from the sticker?
Yes, it was frozen in that I could not turn it by hand even once removed.. I don’t see much corrosion at all. Heater is 2016 by image.jpg
Disconnect the wires from the AFS and check for continuity.
If the switch is closed, the AFS is bad.
get no voltage on IND terminal on ICM
The IND terminal should have 24 VAC on call for heat.
Check Pin 3 of the J1 terminal for 24 VAC.
If you get 24 VAC on pin 3 of the J1 connector, then the wire to the ICM is bad.
If no voltage at Pin 3 of J1, check voltage at Pin 6 of the J2 terminal.
If you have voltage at Pin 6 of the J2 terminal, replace the control board.
If no voltage, a wire might be bad or missing.
Pin 3 on J1 is the inducer (Blower) and there is a wire (Yellow with and Orange stripe) from Pin 3 on J1 to the IND (Blower) on the ICM (Ignition Control Module).
So, if you have 24 VAC on Pin 3 of J1, you should have 24 VAC on the IND terminal of the ICM with the wire connected.
If you disconnect the wire at the IND terminal on the ICM, do you get 24 VAC on the wire?
If no continuity from Pin 3 of J1 to the end of the wire, the wire has a break somewhere.
Maybe a bad end connector?
I
So, if you have 24 VAC on Pin 3 of J1, you should have 24 VAC on the IND terminal of the ICM.
Yes, I get 24 volt on wire unplugged from ICM
