Hi all, I'm a long time fan , first time seeker of help on tfp. I have an in ground pool/spa with a pentair mastertemp 300hd heater installed 2013. Pool has inbuilt cleaning and is intelliflow controlled. Serviced regularly, pool is salt with good water Chem. Varriable Pump at 2300rpm. So all's well until a few weeks ago when the heater starts cycling. First it was a few min"s then sec's then ten min, then sec's again no real pattern Pentair service guy comes out spends 8hrs over 2 days testing and lamenting and finally gives an invoice with the conclusion "touch pad replaced X$$, how ever " heater beyond economical repair". Wow. He states that he can t find anything wrong with it and it might be sooted up. So i decide to open the can. No soot. no water gave it a vac and the pipes a clean with and put it back together. Still cycles no change.
So heres the some data - Call for heat- Fan on ( never stops in mode) - click - gas - ignition runs??? flame out - call for heat .........
Gas type lpg. no error codes ever / no service leds ever / no ICM leds ever / no lockout ever
nano readings 3.1 static -2.8 dynamic - new igniter ohms 75
Water flow ok, - Filters Clean - Pressure switch ok / jumped and multi -Thermal reg opens no prob - new thermaster ok /jumped and multi
new fenwal plus added extra ground wire / multi tested ok - new PCB - HLS and AGS ok /jumped and multi - SFS jumped and multi.
All this and the unit is in good order with no corrosion or damage. So what have i or pentair guy overlooked? It does heat to the set temp eventually, but just cycles its way there and sometimes even goes for 30mins without cycling. Sometimes it just doesnt want to play and endlessly cycles in 45sec - 1min intervals for as long as i let it without stopping and never gets to temp.
hoping the gurus of tfp can help.
TXGi
TXGi
