- Jan 30, 2014
- 26
- Plaster
- Liquid Chlorine
- Pentair Intellichlor IC-40
I have tried to find a solution to this issue but have not found it. Maybe I am just not following the correct procedure.
Scenario- (I came back to this after a week of vacation)
I have to power on the heater via the circuit breaker, since the On/Off switch does not perform this function. When the heater turns on it goes through the proper sequence to show the ROM code and then shows the temp. After about 10 seconds, it throws the AD0 on the display. Pressing On/Off does nothing.
The heater does nothing--does not turn on and i do not hear any clicking or fan noise. The Service and Pool LEDs are lit, but I cannot switch to Spa nor turn On or OFF via touch panel. If I power off the heater via circuit breaker it repeats only what I have walked through above.
Thanks for your hints and help.
Dennis
Dennis
