I have a Mastertemp 250, I installed it less than a month ago. It was working great until last week. I started to get AFS and IGN errors, more often the IGN error though. The heater will try to start up and begin the firing process just fine, the igniter lights the gas, the exhaust gets hot for a couple of seconds and then the firing shuts down. The heater does this cycle a couple more times and then flashes the error codes and shuts off. I have only had the IGN error for the last 3-4 attempts. The AFS error seems to have stopped.
I pulled the AFS tubing out and made sure that it was clean and there are no blockages. I pulled the igniter and it looks fine and measures 50 ohms when cold. I pulled the flue gas sensor and it also looks brand new. I removed the bottom bolt of the manifold and there is no water in the combustion chamber. I have searched other posts and haven't found symptoms that match this, or solutions that I have not tried.
Does anyone have any advice on what the problem could be? or next steps on the diagnosis process? Are there any other issues that might cause the heater to throw those codes that are not related to AFS or IGN?
