Hi guys,
I just bought a home with a Marquis Costal series Spa (see attached pictures).
My issue is with the heating, I set it to 104F but it only heats to ~94F. In addition, it cools down while we use it to below 80F and the heater does not activate.
I have checked the following:
1. Heater relays are ok (resistance across all relay coils are equal)
2. Heating element Ok (resistance computes to rated Kw)
3. Temp sensor ok (reads water temperature and displays on top side controller)
4. Pressure switch ok (I also bridged it out for testing)
5. Pumps run fine and flow is good
6. Heating element housing has a sensor, but I can’t check or test
Does anyone know how to test the heating element sensor or have any suggestions?
I suspect it might be a setting on the top side controller but I can’t find a manuals.
