One of my actuator valves is stuck in spa mode. When I try to use the manual switch on the side the valve will not move. I need to manually move the valve back to pool mode until I can get the valve looked at. I’ve read for other valve brands you can do this by loosing the nut at the top of the valve handle. However, this doesn’t seem to work for the Pentair.
Any suggestions would be appreciated
