We just had our liner replaced and re-filled and salted our pool. Initially, the water looked clear and blue. Once I dialed in the SWC and brought the FC to around 2, a green tint developed, not cloudy, jut a tint as others have mentioned. I know our well has Iron concentration around 3ppm, but find it odd that we did not see this with our previous liner. I suppose it could be the time of year and perhaps the iron concentration is higher. I typically only need to adjust the SWC, add muratic acid, and clean the filters. Curious if what I am seeing could be coming off the new liner, or is it just Iron?
I've read many pages of posts here about HTT, Jacks Magic, ProTeam Magic, and Poly-fil. I'm not sure that I completely understand what happens if I use one of the products to reduce the iron, does the chemical stay in the water or break down? Do I have to keep adding the chemical as part of a regular maintenance? The poly-fil in the skimmer method is appealing as I like the idea of removing the Iron, but I'm not thinking that will work on clear-tint vs. cloudy water.
Looking for recomendations to solve the problem in the most natural way possible. Thank you!
