- Apr 10, 2018
- 5,204
- Plaster
- CircuPool RJ-45
I am trying to manage my water chemistry to avoid calcium scaling and/or damage to my finish or equipment. I'm relatively new to TFPC. I know my CH and CYA are high, but my goal is to work with my current chemistry as far as I can take it. An algae bloom would probably push me to do a drain and refill since required shock levels would be astronomical. I understand the relationship between CYA and FC levels and have been maintaining my FC at 6 ppm and above. My pool gets full sun during the day. Water is clear (the best it has ever looked) with no signs of algae. I just ran an OCLT and passed. I plan to put my solar cover on this weekend, which may make things a bit more challenging.
Here is my most recent test.
FC - 7
CC - 0
pH- 7.4
TA - 90
CH - 750
CYA - 120
Borates - 40
Salt - 4000
It was suggested that I run my pH on the low side and work on lowering TA to 50-70. My current CSI is showing -0.26. Lowering TA and pH result in a lower CSI.
I've read that one way to lower TA is to bring pH down with MA and wait until is rises to 7.8 before adding more MA. My pool seems pretty happy around the 7.4 to 7.5. Should I add MA to bring it down to 7.2 now to reduce TA or aerate to a higher level first?
I'm looking for some input on fine tuning the numbers I have control of to mitigate potential damage.
Mike.
FC - 7
CC - 0
pH- 7.4
TA - 90
CH - 750
CYA - 120
Borates - 40
Salt - 4000
Mike.
