- Jun 22, 2014
- 47,873
- Fiberglass
- CircuPool RJ-45 Plus
The numbers look good if your CYA is 30 and not 40. Yes, the CYA is a bit tricky. As you fill the tiny tube with the black dot, the quicker the dot disappears the higher your CYA is. So it makes sense what you said that you added more water to get to a CYA of 30. Remember after testing CYA, you can pour the solution back to the mixing bottle and re-pour back to the skinny tube as much as you want to confirm. Looks like you're doing really well, so hang in there and keep us posted.
