Feature request submitted.Send feature requests to [email protected]
The Ideal/Suggested ranges are based on the pool surface types and method of chlorination. They are based on TFP standards.
Exactly. That’s all the more reason to get away from hard coded recommendations that are not always recommended on this site by mods. Customizability of this nature will be a win for all.
The version history listed on the App Store shows 6 years of release information with the most recent update being a year ago.
Just trying to help with a fresh perspective from a new guy. Sometimes that helps.
Thats my beef with it, and its a common ploy of the pool store. 'You're numbers are ok, but they need to be ok-er'.Ideal is a smaller range than recommended.
Matt and others,Send feature requests to [email protected]
You’re the second person that thinks you can turn off the ideal ranges. There is no such option! What you are getting confused with is the option to turn off the ideal alerts from being displayed across the top of the screen. Test the setting both ways and you’ll see that I’m right.Don't look at "ideal" ranges - as long as the results are in the recommended range, it's good enough.
Just turn off "ideal range" in PoolMath and forget about it.
Don't micro manage your pool water.
There are slight variations in certain ranges for both pool surface (vinyl, plaster/pebble) and chlorination method (liquid chlorine, SWG).
I appreciate the example you provided. If I understand correctly, the root cause in that scenario would be pool water that is presumably out of balance due to higher than recommended CYA levels. With balanced pool water, my understanding from this site is that ongoing MA demand will tend to be higher when TA is maintained around 90 vs say 60.If a person were to manage their pool using chlorine pucks (trichlor), say, someone who lives on the northeast that draws water from an aquifer with low TA and low pH (more common there), then having a TA in the 50-60ppm range as a recommendation would likely cause them to have a crashing pH and constantly adding baking soda to support the TA that gets reduced by the acidic chlorine source and rain water overflow that has almost no alkalinity in it. That user would need to keep their TA closer to upper range and might even benefit from having a TA near 90 or 100ppm. They’d likely have a vinyl liner pool (more common there) and so CSI is mostly irrelevant.
And yes, the App has different ranges and targets for different pool surfaces.
Thanks BperryOnly if you're chlorinating with a SWG or liquid chlorine.
The major things that cause pH rise (MA demand):With balanced pool water, my understanding from this site is that ongoing MA demand will tend to be higher when TA is maintained around 90 vs say 60.
Thanks for sharing these examples. Seeing it summarized this way is helpful.The major things that cause pH rise (MA demand):
High TA.
Low pH.
Uncovered pool.
New plaster
Things that slow pH rise:
Lower TA (60-90)
higher pH (7.8-8.2)
Covered pool (solar cover)
Older Plaster
Borates
Oh they do…Thanks for sharing these examples. Seeing it summarized this way is helpful.
Funny how pool stores don’t know much about the many benefits of Borates.
There are downsides. Borates will lower pH when you add them. If you add borates, say when at pH is at 7.6, to a 30K pool, your pH will lower to 7.4...and stay there.Funny how pool stores don’t know much about the many benefits of Borates.
There are other side effects. There are other empirically derived indices that are used to predict when corrosion MIGHT be possible. The Pukorius Index (PI) and Ryznar Index (RI) are used in this regard, with my test results and worst case scenario (CSI < -0.9), my Ryznar Index value is 9.15. Anything over 8 is considered corrosive to steel. Even if I increase my CH to 250ppm and my TA to 80, the RI would still be 8.2. This is corrosive towards steel. Either way, these indices only tell me what COULD happen, not what will happen. In my case, my 316 Marine Stainless Steel ladder shows significant signs of corrosion.
Given my experience, I would avoid borates and simply manage pH with muriatic acid.
already borated the pool.
Are you saying that after you added boric acid, your PH stayed low enough that you no longer needed to add MA? Or, does PH eventually rise above 8.0?There are downsides. Borates will lower pH when you add them. If you add borates, say when at pH is at 7.6, to a 30K pool, your pH will lower to 7.4...and stay there.
Your pool math logs are incomplete and do not show your chemical additions. You should add them to pool math as you add chemicals...really helps us troubleshoot what you are doing.Are you saying that after you added boric acid, your PH stayed low enough that you no longer needed to add MA? Or, does PH eventually rise above 8.0?
