Howdy All -
In the last week I noticed that my main pool pump is not holding prime over night. When I turn on the pump there are a lot of bubbles in the pool until the air is flushed out of the system. The pump catches prime and fills with water within 30 seconds. When the pump is running I see zero air in the strainer basket looking through the top. If I turn off the pump it will hold the prime for several hours at least but not overnight. I do not see any water anywhere around the equipment pad. I have tightened down all parts and even replaced the o rings on the pump for the strainer basket and drain plugs. I walked the yard and cannot see any areas that are wet but of course I cannot see under the decking. I also haven't noticed any significant loss of water from the pool nor have I used any excess water according to my water bill. Anyone have any ideas where to look next?
