Yes. If it has power, fire it up!1-- Can I manually turn this pump on at the pump controls, so I can have the pool filter running?
Where do those wires go?There are already two green wires and two yellow wires connected to those terminals.
Yup, that is what I said.The green and yellow wires of the RS-485 cable coming from the vst pump connect to the salt surge board, and not the J20 COMM port?
Thanks!
So, replacing single speed Whisperflo and installing Whisperflo VST:
1--Remove black and red wires from the pump relay and connect them directly to pump breaker.
2--Connect green and yellow wires from automation cable from pump to COMM port on surge board.
3-- Do you keep all the wires connected to the J20 COMM port (two reds, two yellows, two greens, two blacks, coming from the salt board and the antenna) alone? Leave them connected right whwere they are?
4--Do you keep the white and yellow wires (coming from the large transformer)connected to the relay?
Do you understand the relay screws LINE and LOAD?5--Anything else?
This was discussed with you in posts 18-20.I didn't until you just told me.
Sorry, could you tell me specifically (Wiring for dummies) what wires connect to each screw, left to right (Line1, Load1, line2, load2)?
See post 55 above.Screw 1: black wire with blue tape goes to pump breaker.
Screw 2: black wire goes through conduit to pump; white wire goes to large transformer
Screw 3: red wire with blue tape goes to pump breaker
Screw 4: red wire goes through conduit to pump; yellow wire to large transformer
TFP is a member supported 501(c)3 non-profit that is volunteer staffed and has no ads. Your support keeps the servers running so we can be here to help you. It would be helpful if you considered supporting TFP so we can be here to help in the future....Got it. Thank you for your time and patience.
