- May 31, 2022
- 14
- Vinyl
- Pentair Intellichlor IC-15
I know this is a dumb question considering we've had our pool for 5 years now. I read people posting about shutting off their main drain or adjusting the flow between the main drains and the skimmer. We have two pipes coming into our pump but we have 1 skimmer and 2 main drains. Here's my questions. (1) When someone says they are turning their main drain off, I assume they mean they are closing the valve? (2) Is it safe to assume that the two main drains probably connect under ground and then feed into the pump through one pipe while the other pipe is connected to the skimmer?
