So…I figured out in August that my return lines are leaking somewhere. I was losing water and found a leak at one of my skimmers, but even after I had it repaired I was losing a lot of water. Long story short, I had to quit using the filter/pump because we’d just lose too much water.
I called the pool co to do a leak detection test with the equipment that located leaks underground. I thought about doing it myself but I have some serious family issues at the moment and don’t have time nor energy to dive into something like that. Pool co was busy closing so put me off for a few weeks. Then their device broke and they never returned another one of my calls.
I called the guy that rebuilt my pool, hoping he is still alive. (See my initial post for explanation.) He is alive, but when I talked to him (mid October) he was just recovering from another near fatal episode and too busy catching up to help. He said he’d call me in a month (mid November) to schedule a time to come by.
He never did, and his vm is full. My life is living heck right now (family issues) and I have zero time to even shower sometimes (not kidding) so here we are in December and I’m panicking about the still open pool.
I was told by the pool builder guy that all I had to do was open the drain plugs on the filter and pump so let the water run out and I’d be ok for a while (till we have consistently freezing/cold weather) so I did that, but it seems there must have been water in the valve because it’s cracked.
So, I was going to attempt to clean the swamp and then blow out the lines myself but now I have no idea what to do.
I still have the leak in the return lines somewhere too.
If I cut the (main drain) valve out (cuz that’s what needs to happen now to replace it) can I use that point in the line to blow out the lines?
The water level is quite high, so I will have to siphon the water out or use a sump pump. Or, should I get those duck valve things that I’ve seen mentioned elsewhere on this site? What’s easiest. It’s just me, some freezing cold swamp water, and not a lot of time.
Is there a way I could suction/siphon/pump the water out of the lines instead of blowing it out? I already have my winter plugs in the returns. Maybe just enough to get some antifreeze in?
I await any advice you guys and gals have for me. We have about a week of milder weather coming up so I have a window of opportunity to save my pool from total destruction.
