Main drain fixture question
ConcreteChris
Active member
Aug 10, 2020
25
Rhode Island
Getting ready to put in fixtures in to rebar.. (skimmers, main drain)... In the engineered plans the main drain calls for a 4" tunk.. The plans also spec out two main drains called
" Lawson aquatic 9 super-sump vgb certified" anyway the port where is connects is a 4" connection but not open. It is sealed with only looks like a 1/2 treaded hole with a cap screwed in....... My question is, do i cut the 4" hole open before gluing on? Why a 4" line when the feed hole is only 1/2".. any help would be great,
I have never had any experience with that one but I suspect the 4" plug pops out if you put a 1/2" pipe in the center and pry it out (i.e. pop out). Also, I would think you want to do that before attaching the pipe.
@jimmythegreek may know for sure.
Reactions: Texas Splash
It definitely doesnt "pop" out i would have to drill it... Im attaching a couple actually photos
