When you perform the Calcium Hardness Test, do you swirl as you drop when adding R-0012 one drop at a time of until the color changes to blue?
I am asking because the color changes more quickly when I stir as I drop and I want to make sure I am getting an accurate test result.
The Calcium Hardness Test is the only TF100 Test that doesn’t mention “swirling as you drop,” on the direction card but I wanted to check here with the experts.
Thanks
Thanks
