- May 23, 2015
- 24,443
- Plaster
- Pentair Intellichlor IC-60
Can you wet sand a small area of it?
The acid likely etched the surface, taking out the carbonate components, and made the surface porous. A roughened surface will look very different than a smoothed trowel surface. I have a pool deck that is acid-washed concrete and a walkway that is salt-finished. The salt finish is nothing more than a final trowel (smooth) with rock salt pressed in and then removed later. Even though they were poured form the exact same truck of integral colored concrete, they two surfaces look like they are different colors. The surface finish is what makes the difference.
So if you can, wet sand a small area to see if it restores the color at all.
