I have a Jandy LXi400 heater that gives me a "FAULT - CHECK IGN CONTROL" when I turn on the heat.
I've read a few threads and followed the troubleshooting guide (https://www.parts4heating.com/v/vspfiles/Troubleshooting/LXiTS.pdf) which led me straight to Step13.
Rather than getting 24VAC at the air pressure switch; I'm getting about 8VAC. As such; I replaced the air pressure switch. No difference. Still only getting 8VAC.
Any ideas what to try next?
The exact symptom is; I turn on heat remotely (using my PDA). The blower comes on and I hear the ignition module click 3 or 4 times (or more likely it's the gas valve that's clicking open) before the fault appears and the blower shuts off.
One thing that I'm doing slightly differently is where it says "24 VAC between Orange (NO) wire at the Air Pressure Switch and Yellow (1) wire on the Transformer?" ; I'm actually testing against the grounding screw on the front panel instead of the wire directly on the transformer.
The transformer seems to be hard to reach and I figure the Yellow (1) wire on it goes to ground anyway. I guess I should test as instructed but I don't see an easy way to reach the transformer.
Any and all advice, berating, bbq sauce recipes accepted. Thanks!
