This is a new one for me, now when I finally get my numbers where I thought they needed to be to be balanced and now check to see how the overall water condition is, it's way off.
I played around with the calculator it to find it's because of the water temperature. I had input 80 degrees a couple of months ago and I re-checked it is now 55 degrees. To get the numbers I need to get to between -6 to 6 means I need to raise my PH from 7.4 to 7.8 (which I understand will lower the effectiveness of my chlorine) and the TA from 80 to 120 now to get CSI/LSI from -59 to -2. This just gets more mind boggling! Why does the temperature cause my pool to appear in trouble now? And what will it mean to now increase my PH/TA for the winter months? I never realized I would have to make changes in water balancing just chlorine level and maybe less pump run time.
CH 300
CYA 30
Borates 30
Salt 2750
CH 300
CYA 30
Borates 30
Salt 2750
