Current levels are:
FC 6
pH 7.5
TA 90
CH 450
Salt 3800
CYA 70
Temp 16C
That gives CSI -0.32
I add acid to lower the pH when it exceeds 7.8, which also lowers the TA. I've been intending to let TA drop to around 60 before replenishing, as per TFP recommendations.
However, with a TA of 60 and pH of 7.2 I'd get CSI -0.83.
To keep CSI above -0.6 when lowering pH to 7.2 I'd need to keep TA at least 90.
Should I be leaving TA up around 90+ mark?
Or should I not worry about going below -0.6 for a little while?
Should I only be lowering pH to 7.4 or maybe even higher?
FC 6
pH 7.5
TA 90
CH 450
Salt 3800
CYA 70
Temp 16C
