- May 3, 2014
- 62,873
- Fiberglass
- Pentair Intellichlor IC-40
Looks good. I doubt you have a reagent issue.
The OTO could be gettting washed out due to high TC. Just keep adding chlorine and testing FC. Do not mess with testing CC.
No detriment as long as you are staying at or below SLAM level FC.
Can you fill out your signature? The information really helps us help you.
I was afraid of ammonia. It takes at least 10 ppm of chlorine added to eliminate one ppm of ammonia. So I suspect it would be better for you to drain your pool. Or at least most of it
I did not press that at first as you said you had CYA in the water and also you were measuring FC. If you have ammonia, both of those are typically 0.
You can do it in several cycles. Biggest threat in your area is the pool shell lifting from the ground due to ground water. But doing half and then half again will get your ammonia level down to where you can kill it off with just a few gallons of bleach.
