- Apr 23, 2013
- 24
- Plaster
- Pentair Intellichlor IC-40
I use TF-100 test kit. Two months ago my CYA was 60. Today it is down to less than 20. I filled the CYA test tube to the top and the water is cloudy, but I can still see the black dot. I measured a second time with the same result. This is confusing because as far as I know CYA doesn't decrease. I have not used the pool at all this season, so no splash out. I barely even add any water because the solar cover really helps with evaporation. So the only thing I can think of is that the CYA reagent is bad. I got the kit in April. What else can make CYA decrease?
It's a fresh water 14,500 gal in-ground pool.
Here are my test results from 2 months ago:
FC 7
TC 7
CH 225
TA 100
CYA 60
Here are my results from today:
FC 2.5
TC 2.5
CH 175
TA 90
CYA < 20
I also used a test strip for comparison and stabilizer seems to be in the ideal range - 30-50ppm. Chlorine in this picture is higher because I did the test after adding chlorine.
FC 7
TC 7
CH 225
TA 100
CYA 60
FC 2.5
TC 2.5
CH 175
TA 90
CYA < 20
