Lower CYA and fighting algae.
Welcome to TFP!!! :paddle:
Bioactive does not work to reduce CYA. We have 100s of thread with failure.
The only way to reduce CYA is exchanging Water.
At CYA 180, you will need to exchange about 75% of your water.
How are you testing? You really need a good test kit. Link-->Test Kits Compared
Get your kit ordered today. Assuming your CYA is high, add 5ppm of liquid chlorine a day until your test kit arrives.
Read up on the "no drain water exchange here:
When you get your test kit, do the diluted CYA test here:
Post up full results and we will get you on your way.
After your exchange, you will likely want to follow this process to rid your pool of algae. Link-->SLAM Process
Reactions: kimkats
