Hi:
I have a hayward 1 hp northstart pump... with a A & A infloor cleaning system... 6 zones.. until recently.. pump pressure was 18 to 22 psi.. it flucuated as it went through the different zones. now it is 8 to 10 psi..this is what I have checked so far...
I replaced 5 pop up cleaning heads... no change
I replaced the pressure gauge.. no change
I use a screwdriver to clean out the impeller through the pump basket access .. clean.. no change..
No obvious leaks on the suction side.. no sure about the best method to check this
resiliconed the o rings on leaf catcher sump and pump basket cover..
any ideas on what is causing my low pump pressure... thanks,
