Hot tub is connected to the pool. Last few days, after using the hot tub, I noticed the waterfall from the hot tub to the pool that runs when pump is on high speed has looked weak. Cleaned baskets, cleaned filters, water level is good. Maybe a clog in a pipe from the skimmers to the pump?
Also - for the input to the main pump, there is a pipe from the pool and a pipe from the hot tub, so 2 inputs. When in the "pool" setting only the input from the pool is being used (lever shows "off" for spa input); should both the hot tub and pool inputs be used when in the pool setting? I switched it to spa and the lever moved to the spa input, closing off the pool input.
