I've cared for my in-ground pool for the last 10 years thanks to TroubleFreePool. Lately it seems we need to add water more frequently, at least once a week. I've also had to add CYA three times this year. A week ago today I added granular CYA thinking maybe it would last longer. I added the CYA to the skimmer as directed by the instructions two nights in a row. I ran the filter 24 hours for 2-3 days.
Within a few days I noticed that my Barracuda ran slower and there seemed to be more air under the pump filter lid. I opened the filter lid and put it back on hoping to get it tighter and it helped a little bit then slowed down again. I repeated this twice with the same result. A few days later, yesterday, we noticed the barracuda started slowing down to a stop and the pressure is now down to 5. We backwashed and the flow of water coming out was a lot slower than usual. This didn't solve the issue. We went through the steps recommended under the section "Suction Side Air Leaks" and do not believe we found the issue. We do see bubbles under the filter lid so I still feel that could be it but we didn't see a change when we ran water on the lid. We then did the bucket test but it's only been 20 hours. As of right now the difference between the inside of the bucket water loss and the outside pool water level is ½". We then read the section "Leak Detection". Can someone please explain how I "Plug all the inlets and outlets (returns, skimmers, drains, cleaner lines)"?
Thank you in advance,
BTW we are in Phoenix Arizona where is was about 90 today
