Hello all,
noticed my polaris vacuum wasn't running. I unchooked the robot from the pump discharge pipe and noticed very low flow.
I took the vacuum pump apart and looked at the impeller. it looked ok. The ceramic seal and the connecting spring looked bad so i ended up replacing all three to be sure. Ran the pump again and didn't seem to change anything. The motor spins fine, as far as I can tell. Before and after replacing the impeller the discharge pipe would fill and expand so i assume theres flow and pressure. Even my neighborhood pool guy is stumped at this point. My next plan is to see if something is somehow stuck in the polaris pump discharge line. I don't know how that could have happened but i really don't know what else the solution could be. Any other thoughts?
Before i replaced the impeller it sounded like there was an air sound in the discharge of the polaris pump by the equipment. That sound seems to be gone. strange. But the robot still doesn't move and theres low pressure at the pool discharge area.
