I had been playing with my pump schedule times this past week to be more efficient and didn't realize the SWG only works during the main "Pool" schedule. :-/
My Chlorine level dropped to about 1.0 before I figured it out and adjusted the pool run times back. It's now raising back and currently at 2.0
I have never had CC before in my tests but the last 2 times I tested this week, it has been in the .2 range(never higher). Will this go away as my chlorine levels come back up to 3-4? Is this normal with use, or should I do something? The water looks clear.
Todays test
FC 2.0
CC .2
pH 8.0 - added some acid to bring it to 7.8
TA 70
CH 300
CYA 70
SALT 3510
Temp 87
Thank you in advance!
Todays test
FC 2.0
CC .2
TA 70
CH 300
CYA 70
SALT 3510
Temp 87
