The last few times I have tested my pool the free chlorine is low, but the total chlorine is high. How can I get them aligned? This is a saltwater system, gunite in ground pool.
TFPro ordered. I picked up 2 more gallons of liquid chlorine and will add it. Thanks for the help. I'll post the test results when I get the kit.Get the TFPro. It has the best bang for the buck and has the speed stir in it. Get the salt test addition as well. Get yourself some liquid chlorine so you can get it into the pool as the SWG isn't going to give you a bunch of FC at once, which is what you need. Put 1/3 to 1/2 gallon in each day until you can test with the new kit. Then post all of the water tests.
Calcium Chloride does not lower FC. Turn down your SWG or stop liquid chlorine addition. FC will come down on its own.I need to add Calcium Hardness Increaser to get my Cl & Br down from off scale high, but don't know how much.
TA = 70 instead of 07?Here are the latest results:
TA=07
Turn it off for now.FC=23 (I plan to cut back on my generator)
High FC makes the pH test invalid.pH=8.2 (I'll add 1 gallon muriatic acid)
Take note of @Newdude’s post #14.Cl=Off scale high
Br=Off scale high
Pool looks great. I am just concerned about Cl & Br both so high.
TomEnMS
