Hi.
First of all a big thank you to all the contributors. I found this site three years ago and follow the chemistry recommendations to the letter. No algae. For three years. Ever...... and it's easy! Oh.. and cheaper. Less chemicals and no pool guy.
Perhaps I could have some opinions on this conundrum. I have a heat pump that works at night. 10pm to 7am. Cheap rate electricity. Pretty warm at night in the summer in Australia. If I have the pump on a high flow the temperature differential between in and out is about 1.5-2.0 degrees C. If I have the pump on a lower flow through then the differential can be 2.5-3.0 degrees C. But then the turnover is lower and the reach into the corners is lower. Also, if the skimmer basket gets a bit blocked then the flow can drop below the threshold and the pump turns off.
What would you recommend. High flow or low flow. I would appreciate reasons as well. Helps me understand.
Merry Xmas to all
Zhiv.
Merry Xmas to all
Zhiv.
