As far as your sand filter goes - have u ever done a deep cleaning of it? If not, u may want to give that a go. The sand can get channeled or clumpy & lead to poor filtering. Especially if various pool store potions have been used in the past. It’s something that should be done every season or so.
Here’s the guide for that
This post will walk you through the anatomy of a sand filter, and then provide a video at the end for how to deep clean your sand filter. The filter used in the photos and videos is a Hayward S180T top mount sand filter. The images are of a similar filter. Obviously not all filters are...
www.google.com
Btw - u mentioned you suspected mustard algae, it typically grows on the walls in shaded areas.
Regular algae can appear brown/yellow/orange as well.
To treat Mustard Algae you First complete the slam process- then, after passing ALL 3 end of slam criteria you raise fc to mustard algae slam level for your cya for 24hrs & follow this protocol
Today We are going to show you how you can get rid of mustard algae in your pool. By following the steps in this guide and with no expensive chemicals.
www.troublefreepool.com
This is fairly simple to do at the end of the the slam since fc is already elevated & provides some peace of mind if u suspect MA.
