My pool was just recently drained and refilled. I have four tabs in my chlorinator, and the last test says 2.5 PPM. Also, very little stabilizer / cyanuric acid... yesterday was the first time a test showed above 0 ppm. The tabs I'm using now say stabilized, so I assume they're slowly adding stabilizer. I've held off on adding stabilizer, since you can't take it back out... my local pool place suggested leaving it be while the weather's cold, and when it starts to warm up see how much we'd need to add then.
At some point, I'll probably install a salt system. For now, I'm trying to figure out the best way to get my chlorine up and keep it up.
