- Aug 12, 2022
- 11
- Vinyl
- Hayward Aqua Rite (T-9)
First year with the pool. Not sure this is a problem or not... The VSP is putting out about 40gpm based on my flow meter and the filter is registering like 1-2 psi of pressure. I have 3/4 inch return fittings in the pool. Is the low PSI an issue? Should I reduce the return fittings to 1/2 in an effort to produce more back pressure? The Pool looks very clear and clean so not sure there is an issue but the low back pressure seems lower than normal.
