My spa pump (Challenger with a 2 speed AO Smith/Century motor B2984) was leaking. I’m not sure how long it was leaking--we haven’t used the spa in years, and the pump is in a crawlspace. There was a small amount of calcium/mineral buildup, but nothing that looked too bad. The pump runs 24/7 at low speed.
I replaced the seal, which completely stopped the leak. However, the pump is running really loud. It sounds like it is coming from the middle of the motor, but I can’t really tell. I wouldn’t describe it as a hard grinding (it's more like a whine). There is no difference in the sound (other than it being louder) on the higher speed. When I removed the impeller to change the seal I didn’t notice any binding. The shaft had no rust on it. If I remove the motor end cap over the wiring I can turn the shaft by hand, although with the centrifugal switch in the way I can’t really spin it.
I know it is hard to diagnose bearing problems from sound alone (I could post an audio recording) but is there any chance I got a bad seal or installed it incorrectly? I’ve done it a few times and kept good notes (and used the same type of seal as the last time), so I’m 99% sure I did the install correctly, and assume it would leak if I didn’t (?). I checked the very helpful responses on a prior post about a possible disturbance of the V shaped connection/centrifugal switch, but this all looks okay and the contact opens when the motor is running.
It’s so hard to work in the crawlspace that I don’t want to get in there multiple times unless I have to. I’ve been running the pump a half hour at a time twice a day to get us through this cold spell so the water doesn’t freeze in the spa. The motor does not get in the least bit hot nor does the sound change.
Unfortunately no one around replaces bearings, so if it is the bearings I’ll have to learn how to do the job, but I don’t want to go through all that (getting the motor out is a pain given the location) in case it’s something else.
