Lost 3 inches of water overnight. You will never guess the culprit.
Mar 4, 2015
718
Sugar Land , TX
Woke up to go for a swim and found pool had lost 3 inches of water over night. Now it has been real hot in Houston lately , but not that kind of hot! It just so happened that my pool was running it's morning circulation program. I went back to equipment pad and water was spewing from my old Rainbow Chlorinator that I do not use anymore. I kept it hooked up to system for emergency use since I have Stenner system. The white return tubing installed by PB had deteriorated and was spewing water. So I replaced the tubing and all is well now. If you have your Rainbow still hooked up you might want to double check the tubing.
Happened to me recently also
About three-four months ago, my pool started to loose about 1/4~3/8" of water a day. No obvious leaks. Then one day my wife texted me a picture: A hose that I use between the pump discharge and the filter had sprung a small leak! Problem solved.
